- Feb 13, 2010
- 9,300
Even if it's not a full dvd, it's great to have some update on this !
I know that the Plop boot manager can run ISO, and can be run itself from a USB stick... the only part I never tried is to use a ISO on the SAME STICK with the bootloader... but maybe I will play a bit with this in the weekend...I am curious about your next Steps.
I didn't specified what updateWe're still on 3.2.x so we may have to wait more than one update :/.
got a stack trace in dmesg:
[ 1628.893493] gadget: No serial-number string provided!
[ 1628.893798] gadget: File-backed Storage Gadget, version: 1 September 2010
[ 1628.893798] gadget: NOTE: This driver is deprecated. Consider using g_mass_storage instead.
[ 1628.893829] gadget: Number of LUNs=1
[ 1628.893829] g_file_storage gadget-lun0: ro=1, nofua=0, file: /media/PANDORA/TinyCore-current.iso
[ 1628.898010] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 1628.898132] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
[ 1628.898254] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1628.898254] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1628.898284] usb usb1: Product: MUSB HDRC host driver
[ 1628.898284] usb usb1: Manufacturer: Linux 3.2.30 musb-hcd
[ 1628.898345] usb usb1: SerialNumber: musb-hdrc
[ 1628.900726] hub 1-0:1.0: USB hub found
[ 1628.900756] hub 1-0:1.0: 1 port detected
[ 1629.058715] twl4030_bci twl4030_bci: battery disconnected
[ 1636.700592] gadget: high-speed config #1
[ 1669.981506] musb-hdrc musb-hdrc: remove, state 4
[ 1669.981536] usb usb1: USB disconnect, device number 1
[ 1669.995208] musb-hdrc musb-hdrc: USB bus 1 deregistered
[ 1708.656829] gadget: No serial-number string provided!
[ 1708.657135] gadget: File-backed Storage Gadget, version: 1 September 2010
[ 1708.657135] gadget: NOTE: This driver is deprecated. Consider using g_mass_storage instead.
[ 1708.657165] gadget: Number of LUNs=1
[ 1708.657165] g_file_storage gadget-lun0: ro=1, nofua=0, file: /media/PANDORA/TinyCore-current.iso
[ 1708.661315] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 1708.661682] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
[ 1708.666168] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1708.666168] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1708.666198] usb usb1: Product: MUSB HDRC host driver
[ 1708.666198] usb usb1: Manufacturer: Linux 3.2.30 musb-hcd
[ 1708.666198] usb usb1: SerialNumber: musb-hdrc
[ 1708.669006] hub 1-0:1.0: USB hub found
[ 1708.669036] hub 1-0:1.0: 1 port detected
[ 1708.756408] twl4030_bci twl4030_bci: battery temperature out of range
[ 1738.239105] musb-hdrc musb-hdrc: remove, state 4
[ 1738.239135] usb usb1: USB disconnect, device number 1
[ 1738.252319] Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa0ab00a
[ 1738.252349] Internal error: : 1028 [#1]
[ 1738.252349] Modules linked in: g_file_storage(-) aes_generic wl1251_sdio wl1251 isofs mac80211 cfg80211 ecb aufs squashfs sg usb_storage bluetooth omaplfb(O) pvrsrvkm(O) zram© snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss ipv6 fuse ads7846 hwmon [last unloaded: g_file_storage]
[ 1738.252441] CPU: 0 Tainted: G C O (3.2.30 #699)
[ 1738.252471] PC is at musb_generic_disable+0x18/0x28
[ 1738.252471] LR is at musb_stop+0x24/0x44
[ 1738.252502] pc : [<c026dbf4>] lr : [<c026dc28>] psr: 60000013
[ 1738.252502] sp : c333fee0 ip : 00000000 fp : bea90bd4
[ 1738.252502] r10: 00000000 r9 : c333e000 r8 : cec13078
[ 1738.252532] r7 : 20000113 r6 : bf2547f4 r5 : cec12000 r4 : cec120f0
[ 1738.252532] r3 : fa0ab000 r2 : 00000000 r1 : 00000000 r0 : cec120f0
[ 1738.252563] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1738.252563] Control: 10c5387d Table: 808b4019 DAC: 00000015
[ 1738.252563] Process rmmod (pid: 4919, stack limit = 0xc333e2f0)
[ 1738.252593] Stack: (0xc333fee0 to 0xc3340000)
[ 1738.252593] fee0: cec12000 c0273124 cec12074 c026051c cec12000 00000000 c053506c cec120f0
[ 1738.252624] ff00: 00000000 c0270bd4 ced23a00 bf2545b8 bf2547f4 c333ff44 c0013028 c0275420
[ 1738.252624] ff20: 00000000 c0275484 cd620400 00000000 bf2547f4 bf253c74 00000013 c0063240
[ 1738.252655] ff40: 4020b000 69665f67 735f656c 61726f74 c8006567 ce481a80 c8ca8000 c0098a48
[ 1738.252685] ff60: 4020b000 4020a000 00001000 ce481a80 00000000 ce481ab4 4020a000 00001000
[ 1738.252685] ff80: bf2547f4 00000880 c333ff8c 00000000 00012008 bea90e61 bea90b98 00000880
[ 1738.252716] ffa0: 00000081 c0012e80 bea90e61 bea90b98 bea90b98 00000880 bea90318 00000001
[ 1738.252716] ffc0: bea90e61 bea90b98 00000880 00000081 00000000 00000000 00000000 bea90bd4
[ 1738.252746] ffe0: 17d52173 bea90b90 00009124 401a614c 60000010 bea90b98 00000000 00000000
[ 1738.252777] [<c026dbf4>] (musb_generic_disable+0x18/0x28) from [<c026dc28>] (musb_stop+0x24/0x44)
[ 1738.252777] [<c026dc28>] (musb_stop+0x24/0x44) from [<c0273124>] (musb_h_stop+0x10/0x1c)
[ 1738.252807] [<c0273124>] (musb_h_stop+0x10/0x1c) from [<c026051c>] (usb_remove_hcd+0xd4/0x148)
[ 1738.252838] [<c026051c>] (usb_remove_hcd+0xd4/0x148) from [<c0270bd4>] (musb_gadget_stop+0x150/0x178)
[ 1738.252868] [<c0270bd4>] (musb_gadget_stop+0x150/0x178) from [<c0275420>] (usb_gadget_remove_driver+0x74/0x98)
[ 1738.252868] [<c0275420>] (usb_gadget_remove_driver+0x74/0x98) from [<c0275484>] (usb_gadget_unregister_driver+0x40/0x7c)
[ 1738.252929] [<c0275484>] (usb_gadget_unregister_driver+0x40/0x7c) from [<bf253c74>] (fsg_cleanup+0x34/0x58 [g_file_storage])
[ 1738.252960] [<bf253c74>] (fsg_cleanup+0x34/0x58 [g_file_storage]) from [<c0063240>] (sys_delete_module+0x1dc/0x250)
[ 1738.253021] [<c0063240>] (sys_delete_module+0x1dc/0x250) from [<c0012e80>] (ret_fast_syscall+0x0/0x30)
[ 1738.253021] Code: e5c3200b e1c320b6 e1c320b8 e5c32060 (e5d3200a)
[ 1738.253051] ------------[ cut here ]------------
[ 1738.253082] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0x208/0x298()
[ 1738.253082] In-band Error seen by MPU at address 0
[ 1738.253112] Modules linked in: g_file_storage(-) aes_generic wl1251_sdio wl1251 isofs mac80211 cfg80211 ecb aufs squashfs sg usb_storage bluetooth omaplfb(O) pvrsrvkm(O) zram© snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss ipv6 fuse ads7846 hwmon [last unloaded: g_file_storage]
[ 1738.253173] [<c0019084>] (unwind_backtrace+0x0/0xec) from [<c0038eb8>] (warn_slowpath_common+0x4c/0x64)
[ 1738.253204] [<c0038eb8>] (warn_slowpath_common+0x4c/0x64) from [<c0038f50>] (warn_slowpath_fmt+0x2c/0x3c)
[ 1738.253234] [<c0038f50>] (warn_slowpath_fmt+0x2c/0x3c) from [<c002ab6c>] (omap3_l3_app_irq+0x208/0x298)
[ 1738.253265] [<c002ab6c>] (omap3_l3_app_irq+0x208/0x298) from [<c006d2ac>] (handle_irq_event_percpu+0x28/0x170)
[ 1738.253295] [<c006d2ac>] (handle_irq_event_percpu+0x28/0x170) from [<c006d41c>] (handle_irq_event+0x28/0x38)
[ 1738.253295] [<c006d41c>] (handle_irq_event+0x28/0x38) from [<c006f750>] (handle_level_irq+0xac/0xbc)
[ 1738.253326] [<c006f750>] (handle_level_irq+0xac/0xbc) from [<c006cfbc>] (generic_handle_irq+0x28/0x30)
[ 1738.253356] [<c006cfbc>] (generic_handle_irq+0x28/0x30) from [<c0013d90>] (handle_IRQ+0x60/0x84)
[ 1738.253387] [<c0013d90>] (handle_IRQ+0x60/0x84) from [<c0012a34>] (__irq_svc+0x34/0x78)
[ 1738.253387] [<c0012a34>] (__irq_svc+0x34/0x78) from [<c0038de8>] (oops_exit+0x0/0x18)
[ 1738.253417] [<c0038de8>] (oops_exit+0x0/0x18) from [<0000000b>] (0xb)
[ 1738.253417] ---[ end trace f0adf2a8c607062b ]---
[ 1738.253448] ---[ end trace f0adf2a8c607062c ]---
I already tried those options without good results... anyway I don't remember exactly all the kernel and command combinations, I will try again, good to know it was working, if you find the script can be useful indeedThe options I used was ro=1 removable=1 cdrom=1 file=/asd.iso
