- Jan 18, 2010
- 11,475
Here is the GemRB.log contents on my 1GHz unit:
I'll try my Rebirth unit today.. I'll download a fresh copy of the data from the GOG install.
[Core]: GemRB Core Initialization...
[Core]: Initializing Video Driver...
[Core]: Initializing Search Path...
[ResourceManager/WARNING]: Invalid path given: ./bg1/portraits (Portraits)
[ResourceManager/WARNING]: Invalid path given: ./bg1/Data/data (CD1/data)
[ResourceManager/WARNING]: Invalid path given: ./bg1/CD6/data (CD6/data)
[ResourceManager/WARNING]: Invalid path given: ./bg1/data/CD6/data (CD6/data)
[Core]: Initializing KEY Importer...
[KEYImporter]: Opening ./bg1/chitin.key...
[KEYImporter]: Checking file type...
[KEYImporter]: Reading Resources...
[KEYImporter]: BIF Files Count: 159 (Starting at 24 Bytes)
[KEYImporter]: RES Count: 16694 (Starting at 4780 Bytes)
[KEYImporter]: Resources Loaded...
[Core]: Initializing GUI Script Engine...
[ResourceManager/WARNING]: Invalid path given: /usr/share/fonts/TTF (CustomFonts)
[Core]: Reading Game Options...
[ResourceManager]: Found 'gemrb.ini' in 'GemRB Unhardcoded data'.
[Core]: Loading game type-specific GemRB setup './unhardcoded/bg1/gemrb.ini'
[Core]: Loading original game options from ./bg1/gem-baldur.ini
[ResourceManager]: Found 'defaults.ini' in 'shared GemRB Unhardcoded data'.
[Core]: Reading Encoding Table...
[ResourceManager]: Found 'default.ini' in 'shared GemRB Unhardcoded data'.
[Core]: Loading encoding definition for default: './unhardcoded/shared/default.ini'
[Core]: Creating Projectile Server...
[ResourceManager]: Found 'gemprjtl.ids' in 'GemRB Unhardcoded data'.
[ResourceManager/ERROR]: Couldn't find 'projectl.ids'.
[Core]: Checking for Dialogue Manager...
[ResourceManager/ERROR]: Couldn't find 'gender.2da'.
[Core]: Loading Dialog.tlk file...
[Core]: Loading Palettes...
[ResourceManager]: Searching for 'MPALETTE'...
[ResourceManager]: Found 'MPALETTE.bmp' in 'chitin.key'.
[ResourceManager]: Searching for 'MPAL256'...
[ResourceManager]: Found 'MPAL256.bmp' in 'GemRB Unhardcoded data'.
[Core]: Palettes Loaded
[Core]: Initializing stock sounds...
[ResourceManager]: Found 'defsound.2da' in 'GemRB Unhardcoded data'.
[Core]: Broadcasting Event Manager...
[Core]: Initializing Window Manager...
[Core]: Loading Cursors...
[ResourceManager]: Found 'cursors.bam' in 'chitin.key'.
[ResourceManager]: Found 'fogowar.bam' in 'chitin.key'.
[Core]: Loading Fog-Of-War bitmaps...
[Core]: Loading Ground circle bitmaps...
[Core]: Loading Fonts...
[ResourceManager]: Found 'fonts.2da' in 'GemRB Unhardcoded data'.
[ResourceManager]: Searching for 'NORMAL'...
[ResourceManager]: Found 'NORMAL.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'TOOLFONT'...
[ResourceManager]: Found 'TOOLFONT.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'NUMBER'...
[ResourceManager]: Found 'NUMBER.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'INITIALS'...
[ResourceManager]: Found 'INITIALS.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'NUMBER2'...
[ResourceManager]: Found 'NUMBER2.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'NUMBER3'...
[ResourceManager]: Found 'NUMBER3.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'REALMS'...
[ResourceManager]: Found 'REALMS.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'STONEBIG'...
[ResourceManager]: Found 'STONEBIG.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'STONESML'...
[ResourceManager]: Found 'STONESML.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'STATES'...
[ResourceManager]: Found 'STATES.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'STATES2'...
[ResourceManager]: Found 'STATES2.bam' in 'chitin.key'.
[Core]: Fonts Loaded...
[ResourceManager]: Found 'tooltip.bam' in 'chitin.key'.
[Core]: Initializing Tooltips...
[Core]: Setting up the Console...
[ResourceManager]: Found 'carot.bam' in 'chitin.key'.
[Core]: Starting up the Sound Driver...
[OpenAL]: Initializing OpenAL driver:
AL Version
null)
AL Renderer
null)
AL Vendor
null)
[OpenAL]: Allocated 30 streams.
[Core]: Allocating SaveGameIterator...
[Core]: Initializing Token Dictionary...
[Core]: Initializing Music Manager...
[Core]: Loading music list...
[ResourceManager]: Found 'music.2da' in 'GemRB Unhardcoded data'.
[Core]: Bringing up the Global Timer...
[Core]: Initializing effects...
[ResourceManager]: Found 'efftext.2da' in 'GemRB Override'.
[ResourceManager]: Found 'effects.ids' in 'GemRB Unhardcoded data'.
[Core]: Initializing Inventory Management...
[ResourceManager]: Found 'itemtype.2da' in 'GemRB Unhardcoded data'.
[ResourceManager/ERROR]: Couldn't find 'itemdata.2da'.
[ResourceManager]: Found 'slottype.2da' in 'GemRB Unhardcoded data'.
[Core]: Initializing string constants...
[ResourceManager]: Found 'strings.2da' in 'GemRB Unhardcoded data'.
[Core]: Initializing random treasure...
[ResourceManager]: Found 'randitem.2da' in 'GemRB Unhardcoded data'.
[ResourceManager]: Found 'rndtreas.2da' in 'chitin.key'.
[ResourceManager]: Found 'rndscrol.2da' in 'Override'.
[ResourceManager]: Found 'rndmagic.2da' in 'chitin.key'.
[ResourceManager]: Found 'rndequip.2da' in 'chitin.key'.
[Core]: Initializing ability tables...
[ResourceManager]: Found 'strmod.2da' in 'chitin.key'.
[ResourceManager]: Found 'strmodex.2da' in 'chitin.key'.
[ResourceManager]: Found 'intmod.2da' in 'chitin.key'.
[ResourceManager]: Found 'hpconbon.2da' in 'chitin.key'.
[ResourceManager]: Found 'lorebon.2da' in 'chitin.key'.
[ResourceManager]: Found 'dexmod.2da' in 'chitin.key'.
[ResourceManager]: Found 'chrmodst.2da' in 'chitin.key'.
[Core]: Reading reputation mod table...
[ResourceManager]: Found 'reputati.2da' in 'chitin.key'.
[ResourceManager/WARNING]: 'WMAPLAY.2da' not found...
[Core]: Reading game time table...
[ResourceManager]: Found 'gametime.2da' in 'GemRB Unhardcoded data'.
[Core]: Reading special spells table...
[ResourceManager]: Found 'splspec.2da' in 'GemRB Unhardcoded data'.
[ResourceManager/ERROR]: Couldn't find 'wildmag.2da'.
[Core/WARNING]: Failed to load special spells.
[Core]: Reading item tables...
[ResourceManager]: Found 'itemexcl.2da' in 'chitin.key'.
[ResourceManager/ERROR]: Couldn't find 'itemdial.2da'.
[ResourceManager]: Found 'tooltip.2da' in 'chitin.key'.
[ResourceManager]: Found 'dmgtypes.2da' in 'shared GemRB Unhardcoded data'.
[ResourceManager]: Found 'stats.ids' in 'shared GemRB Override'.
[Core]: Reading damage type table...
[Core]: Reading modal states table...
[ResourceManager]: Found 'modal.2da' in 'shared GemRB Unhardcoded data'.
[Core]: Reading game script tables...
[ResourceManager]: Found 'happy.2da' in 'chitin.key'.
[ResourceManager]: Found 'rmodrep.2da' in 'chitin.key'.
[ResourceManager]: Found 'rmodchr.2da' in 'chitin.key'.
[ResourceManager]: Found 'trigger.ids' in 'chitin.key'.
[ResourceManager]: Found 'action.ids' in 'chitin.key'.
[ResourceManager]: Found 'object.ids' in 'chitin.key'.
[ResourceManager]: Found 'gemact.ids' in 'GemRB Unhardcoded data'.
[ResourceManager]: Found 'gemtrig.ids' in 'GemRB Unhardcoded data'.
[ResourceManager]: Found 'script.2da' in 'GemRB Unhardcoded data'.
[GameScript/WARNING]: Couldn't assign function to trigger: 7 said
[GameScript/WARNING]: Couldn't assign function to trigger: 85 reset
[GameScript]: reallyforcespelldead(o:target,i:spell*spell) overrides existing action 181 reallyforcespell
[GameScript/WARNING]: Couldn't assign function to action: 20 layhands
[GameScript/WARNING]: Couldn't assign function to action: 37 followpath
[GameScript/WARNING]: Couldn't assign function to action: 77 nidspecial8
[GameScript/WARNING]: Couldn't assign function to action: 79 nidspecial10
[GameScript/WARNING]: Couldn't assign function to action: 80 nidspecial11
[GameScript/WARNING]: Couldn't assign function to action: 81 nidspecial12
[GameScript/WARNING]: Couldn't assign function to action: 94 groupattack
[GameScript/WARNING]: Couldn't assign function to action: 183 multiplayersync
[ResourceManager]: Found 'instant.ids' in 'chitin.key'.
[GameScript/WARNING]: instant action 1 (actionoverride(o:actor*,a:action*)) doesn't exist, ignoring
[ResourceManager/ERROR]: Couldn't find 'actsleep.ids'.
[ResourceManager/ERROR]: Couldn't find 'chase.ids'.
[ResourceManager]: Found 'svtriobj.ids' in 'chitin.key'.
[GameScript/WARNING]: saved trigger 85 (reset(o
bject*)) doesn't exist, ignoring
[GameScript/WARNING]: saved trigger 7 (said(o
bject*,i:dialog) doesn't exist, ignoring
[Core]: Initializing keymap tables...
[ResourceManager]: Found 'keymap.2da' in 'shared GemRB Unhardcoded data'.
[Unknown]: Adding key 7 with function GUICommon::ResolveKey
[Unknown]: Adding key 8 with function GUICommon::ResolveKey
[Unknown]: Adding key 9 with function GUICommon::ResolveKey
[Unknown]: Adding key 0 with function GUICommon::ResolveKey
[Unknown]: Adding key - with function GUICommon::ResolveKey
[Unknown]: Adding key = with function GUICommon::ResolveKey
[Core]: Core Initialization Complete!
[SDL 1.2 Driver]: Creating display
[SDL 1.2 Driver]: SDL_SetVideoMode...
[SDL 1.2 Driver]: Checking for HardWare Acceleration...
[SDL 1.2 Driver]: Creating Main Surface...
[SDL 1.2 Driver]: Creating Back Buffer...
[SDL 1.2 Driver]: Creating Extra Buffer...
[GUIScript]: Loading Script Start.
[ResourceManager]: Searching for 'BG4LOGO'...
[ResourceManager]: Found 'BG4LOGO.mve' in 'chitin.key'.
[ResourceManager]: Searching for 'TSRLOGO'...
[ResourceManager]: Found 'TSRLOGO.mve' in 'chitin.key'.
[ResourceManager]: Searching for 'BILOGO'...
[ResourceManager]: Found 'BILOGO.mve' in 'chitin.key'.
[ResourceManager]: Searching for 'INFELOGO'...
[ResourceManager]: Found 'INFELOGO.mve' in 'chitin.key'.
[ResourceManager]: Searching for 'INTRO'...
[ResourceManager]: Found 'INTRO.mve' in 'chitin.key'.
[ResourceManager]: Found 'START.chu' in 'chitin.key'.
[ResourceManager]: Searching for 'guierr2b'...
[ResourceManager]: Found 'guierr2b.mos' in 'chitin.key'.
[ResourceManager]: Found 'guistmsc.bam' in 'chitin.key'.
[ResourceManager]: Searching for 'start'...
[ResourceManager]: Found 'start.mos' in 'chitin.key'.
[ResourceManager]: Found 'gmpconnc.bam' in 'chitin.key'.
[MUSImporter]: Loading ./bg1/music/Theme.mus...
[ResourceManager]: Searching for 'THEME/THEMEA'...
[ResourceManager]: Found 'THEME/THEMEA.acm' in 'Music'.
[Unknown]: Playing: THEME/THEMEA
[OPENAL]: Music in INITIAL State. AutoStarting
[ResourceManager]: Searching for 'gam_09'...
[ResourceManager]: Found 'gam_09.wav' in 'chitin.key'.
AL Version
AL Renderer
AL Vendor
