HackModford
- Oct 2, 2007
- 813
- Age
- 34
Reflashing again just incase...
On Linux most of the .something config files located in the user's home directory are for overwriting settings in a global configuration somewhere else. That way each user can have separate settings, but if no custom user settings are given, it defaults to the global settings. Hence why you can delete the .asoundrc without screwing things up (but also without fixing things).HackModford said:Edite:
What on earth is going on? I just deleted my .asoundrc from my home directory and still have audio! :blink:
Linguist said:The OP-Team is aware of this problem so waiting and drinking coffee is for me the answer.
jasay said:On Linux most of the .something config files located in the user's home directory are for overwriting settings in a global configuration somewhere else. That way each user can have separate settings, but if no custom user settings are given, it defaults to the global settings. Hence why you can delete the .asoundrc without screwing things up (but also without fixing things).HackModford said:Edite:
HackModford said:Mine was full of settings for the omap3beagleboard and omap3pandora
I deleted everything for beagle board... Maybe I should try deleting everything for pandora just to see if it makes a difference. I"m frantic enough to try.
notaz said:Can those with this problem try running PicoDrive a couple of times and tell how it sounds? This will need a ROM but they are easy to obtain.
http://www.gp32x.de/board/index.php?/topic/53899-picodrive-released/
this might give me some ideas depending on results.
