b_o_b
- Sep 7, 2010
- 1,502
Hi
Because of bad onboard wifi on my Pandora I have bought a couple of usb wifi dongles. They all work a lot better than the onboard chip, but still I am having connection issues.
For streaming video (with Kodi and UMS) I need a stable connection or a connection that reconnects immediately. I already bought a wifi repeater to be sure the signal is strong enough.
When connection fails it usually stops and doesn't seem to try to reconnect and if it does it seems to hang in the reconnect phase without ever reconnecting.
I then need to disable USB-host or even pull out the usb wifi dongle and try again.
So my question is - is there any method to improve connection reliability.
OS: SuperZaxxon 1.75 update 2 (just updated it to update 5.. maybe this update helps with this issue)
iwconfig
wlan5 IEEE 802.11bgn ESSID:"Ziggo54867 2" Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency:2.447 GHz Access Point: F4:F2:6D:C3:B3:08
Bit Rate:150 Mb/s Sensitivity:0/0
Retry
ff RTS thr
ff Fragment thr
ff
Power Management
ff
Link Quality=67/100 Signal level=-61 dBm Noise level=0 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lsusb -v
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.02
iManufacturer 3 Linux 3.2.81 musb-hcd
iProduct 2 MUSB HDRC host driver
iSerial 1 musb-hdrc
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0011
Per-port power switching
No overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 5 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0100 power
Device Status: 0x0001
Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
bcdDevice 3.02
iManufacturer 3 Linux 3.2.81 ehci_hcd
iProduct 2 OMAP-EHCI Host Controller
iSerial 1 ehci-omap.0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
wHubCharacteristic 0x0009
Per-port overcurrent protection
bPwrOn2PwrGood 10 * 2 milli seconds
DeviceRemovable 0x00
Hub Port Status:
Port 2: 0000.0503 highspeed power enable connect
Port 3: 0000.0100 power
Self Powered
Bus 002 Device 004: ID 7392:7811
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x7392
idProduct 0x7811
bcdDevice 2.00
iManufacturer 1 Realtek
iProduct 2 802.11n WLAN Adapter
iSerial 3 00e04c000001
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
dmesg | grep -i usb
[ 0.119354] usbcore: registered new interface driver usbfs
[ 0.119689] usbcore: registered new interface driver hub
[ 0.120025] usbcore: registered new device driver usb
[ 0.133422] print_constraints: VUSB1V5: 1500 mV normal standby
[ 0.134277] print_constraints: VUSB1V8: 1800 mV normal standby
[ 0.135101] print_constraints: VUSB3V1: 3100 mV normal standby
[ 0.195434] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.244232] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.249938] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.249969] musb-hdrc: MHDRC RTL version 1.400
[ 0.249969] musb-hdrc: setup fifo_mode 4
[ 0.250000] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.250640] musb-hdrc musb-hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 1.599884] usbcore: registered new interface driver libusual
[ 1.882659] usbcore: registered new interface driver usbhid
[ 1.882659] usbhid: USB HID core driver
[ 15.776123] usb0: MAC
[ 15.776153] usb0: HOST MAC
[ 15.795715] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 15.795867] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
[ 15.795989] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 15.796020] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 15.796020] usb usb1: Product: MUSB HDRC host driver
[ 15.796020] usb usb1: Manufacturer: Linux 3.2.81 musb-hcd
[ 15.796051] usb usb1: SerialNumber: musb-hdrc
[ 15.798431] hub 1-0:1.0: USB hub found
[ 63.505981] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 64.515319] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 64.526977] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 64.527099] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 64.527099] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 64.527130] usb usb2: Product: OMAP-EHCI Host Controller
[ 64.527130] usb usb2: Manufacturer: Linux 3.2.81 ehci_hcd
[ 64.527130] usb usb2: SerialNumber: ehci-omap.0
[ 64.529602] hub 2-0:1.0: USB hub found
[ 64.855224] usb 2-2: new high-speed USB device number 2 using ehci-omap
[ 65.014190] usb 2-2: New USB device found, idVendor=7392, idProduct=7811
[ 65.014221] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 65.014221] usb 2-2: Product: 802.11n WLAN Adapter
[ 65.014221] usb 2-2: Manufacturer: Realtek
[ 65.014251] usb 2-2: SerialNumber: 00e04c000001
[ 65.443542] usb_endpoint_descriptor(0):
[ 65.443572] RT_usb_endpoint_is_bulk_in = 1
[ 65.443603] usb_endpoint_descriptor(1):
[ 65.443634] RT_usb_endpoint_is_bulk_out = 2
[ 65.443634] usb_endpoint_descriptor(2):
[ 65.443664] RT_usb_endpoint_is_bulk_out = 3
[ 65.443664] usb_endpoint_descriptor(3):
[ 65.443725] RT_usb_endpoint_is_int_in = 4, Interval = 1
[ 65.443725] USB_SPEED_HIGH
[ 65.695312] ### PS params=> power_mgnt(1),usbss_enable(0) ###
[ 65.700927] usbcore: registered new interface driver rtl8192cu
[ 69.164825] usb_read_port_cancel
[ 69.185455] usb_read_port_complete()-1341: RX Warning!
[ 69.189453] usb_read_port_complete()-1341: RX Warning!
[ 69.189544] usb_read_port_complete()-1341: RX Warning!
[ 69.189697] usb_read_port_complete()-1341: RX Warning!
[ 69.189697] usb_write_port_cancel
[ 74.801605] usb_read_port_cancel
[ 74.801788] usb_read_port_complete()-1341: RX Warning!
[ 74.801910] usb_read_port_complete()-1341: RX Warning!
[ 74.802032] usb_read_port_complete()-1341: RX Warning!
[ 74.802154] usb_read_port_complete()-1341: RX Warning!
[ 74.802215] usb_write_port_cancel
[ 162.669769] usb 2-2: USB disconnect, device number 2
[ 162.670104] ###=> usb_read_port_complete => urb status(-108)
[ 162.670104] usb_read_port_complete()-1341: RX Warning!
[ 162.670135] usb_read_port_complete()-1341: RX Warning!
[ 162.670501] reg 0x1cc, usb read fail ,status:-19 value=0x0
[ 162.679321] usb_read_port_cancel
[ 162.679351] usb_write_port_cancel
[ 203.035125] usb 2-2: new high-speed USB device number 3 using ehci-omap
[ 203.193115] usb 2-2: New USB device found, idVendor=0bda, idProduct=8179
[ 203.193115] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 203.193145] usb 2-2: Product: 802.11n NIC
[ 203.193145] usb 2-2: Manufacturer: Realtek
[ 203.193145] usb 2-2: SerialNumber: 00E04C0001
[ 203.692657] usbcore: registered new interface driver rtl8188eu
[ 1002.987487] usb 2-2: USB disconnect, device number 3
[ 1043.151733] usb 2-2: new high-speed USB device number 4 using ehci-omap
[ 1043.312255] usb 2-2: New USB device found, idVendor=0bda, idProduct=8179
[ 1043.312255] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1043.312286] usb 2-2: Product: 802.11n NIC
[ 1043.312286] usb 2-2: Manufacturer: Realtek
[ 1043.312286] usb 2-2: SerialNumber: 00E04C0001
[ 5941.482971] usb 2-2: USB disconnect, device number 4
[19023.042541] usb 2-2: new high-speed USB device number 5 using ehci-omap
[19023.200561] usb 2-2: New USB device found, idVendor=0bda, idProduct=8179
[19023.200561] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[19023.200592] usb 2-2: Product: 802.11n NIC
[19023.200592] usb 2-2: Manufacturer: Realtek
[19023.200592] usb 2-2: SerialNumber: 00E04C0001
[67442.607910] usb 2-2: USB disconnect, device number 5
[67443.925140] hub 2-0:1.0: unable to enumerate USB device on port 2
[67594.309265] usb usb2: USB disconnect, device number 1
[67594.331726] ehci-omap ehci-omap.0: USB bus 2 deregistered
[67603.835662] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[67604.842895] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[67604.854980] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[67604.855102] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[67604.855102] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[67604.855133] usb usb2: Product: OMAP-EHCI Host Controller
[67604.855133] usb usb2: Manufacturer: Linux 3.2.81 ehci_hcd
[67604.855133] usb usb2: SerialNumber: ehci-omap.0
[67604.857727] hub 2-0:1.0: USB hub found
[67605.183258] usb 2-2: new high-speed USB device number 2 using ehci-omap
[67605.341278] usb 2-2: New USB device found, idVendor=0bda, idProduct=8179
[67605.341308] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[67605.341308] usb 2-2: Product: 802.11n NIC
[67605.341339] usb 2-2: Manufacturer: Realtek
[67605.341339] usb 2-2: SerialNumber: 00E04C0001
[67636.226837] usb 2-2: USB disconnect, device number 2
[67649.042602] usb 2-2: new high-speed USB device number 3 using ehci-omap
[67649.200622] usb 2-2: New USB device found, idVendor=0bda, idProduct=8179
[67649.200622] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[67649.200653] usb 2-2: Product: 802.11n NIC
[67649.200653] usb 2-2: Manufacturer: Realtek
[67649.200653] usb 2-2: SerialNumber: 00E04C0001
[67659.306945] usb usb2: USB disconnect, device number 1
[67659.306945] usb 2-2: USB disconnect, device number 3
[67659.397155] ehci-omap ehci-omap.0: USB bus 2 deregistered
[67678.908111] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[67679.919097] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[67679.933105] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[67679.933227] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[67679.933227] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[67679.933258] usb usb2: Product: OMAP-EHCI Host Controller
[67679.933258] usb usb2: Manufacturer: Linux 3.2.81 ehci_hcd
[67679.933258] usb usb2: SerialNumber: ehci-omap.0
[67679.935699] hub 2-0:1.0: USB hub found
[67680.261352] usb 2-2: new high-speed USB device number 2 using ehci-omap
[67680.419342] usb 2-2: New USB device found, idVendor=0bda, idProduct=8179
[67680.419342] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[67680.419372] usb 2-2: Product: 802.11n NIC
[67680.419372] usb 2-2: Manufacturer: Realtek
[67680.419372] usb 2-2: SerialNumber: 00E04C0001
[67977.937652] usb 2-2: USB disconnect, device number 2
[67993.068572] usb 2-2: new high-speed USB device number 3 using ehci-omap
[67993.226715] usb 2-2: New USB device found, idVendor=0bda, idProduct=8179
[67993.226745] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[67993.226745] usb 2-2: Product: 802.11n NIC
[67993.226745] usb 2-2: Manufacturer: Realtek
[67993.226776] usb 2-2: SerialNumber: 00E04C0001
[67995.670318] usb 2-2: USB disconnect, device number 3
[68004.950714] usb usb2: USB disconnect, device number 1
[68004.976104] ehci-omap ehci-omap.0: USB bus 2 deregistered
[68041.325866] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[68042.336700] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[68042.349945] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[68042.350097] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[68042.350097] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[68042.350128] usb usb2: Product: OMAP-EHCI Host Controller
[68042.350128] usb usb2: Manufacturer: Linux 3.2.81 ehci_hcd
[68042.350128] usb usb2: SerialNumber: ehci-omap.0
[68042.352813] hub 2-0:1.0: USB hub found
[68053.733520] usb usb2: USB disconnect, device number 1
[68053.746826] ehci-omap ehci-omap.0: USB bus 2 deregistered
[68069.307312] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[68070.312927] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[68070.326812] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[68070.326934] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[68070.326934] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[68070.326965] usb usb2: Product: OMAP-EHCI Host Controller
[68070.326965] usb usb2: Manufacturer: Linux 3.2.81 ehci_hcd
[68070.326965] usb usb2: SerialNumber: ehci-omap.0
[68070.329589] hub 2-0:1.0: USB hub found
[68070.967376] usb 2-2: new high-speed USB device number 2 using ehci-omap
[68071.137298] usb 2-2: device descriptor read/all, error -71
[68071.193969] hub 2-0:1.0: unable to enumerate USB device on port 2
[68089.717468] usb 2-2: new high-speed USB device number 4 using ehci-omap
[68089.876800] usb 2-2: New USB device found, idVendor=7392, idProduct=7811
[68089.876800] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[68089.876831] usb 2-2: Product: 802.11n WLAN Adapter
[68089.876831] usb 2-2: Manufacturer: Realtek
[68089.876831] usb 2-2: SerialNumber: 00e04c000001
[68089.879669] usb_endpoint_descriptor(0):
[68089.879699] RT_usb_endpoint_is_bulk_in = 1
[68089.879699] usb_endpoint_descriptor(1):
[68089.879730] RT_usb_endpoint_is_bulk_out = 2
[68089.879760] usb_endpoint_descriptor(2):
[68089.879791] RT_usb_endpoint_is_bulk_out = 3
[68089.879791] usb_endpoint_descriptor(3):
[68089.879821] RT_usb_endpoint_is_int_in = 4, Interval = 1
[68089.879852] USB_SPEED_HIGH
[68090.172912] ### PS params=> power_mgnt(1),usbss_enable(0) ###
[68093.852691] usb_read_port_cancel
[68093.855468] usb_read_port_complete()-1341: RX Warning!
[68093.855560] usb_read_port_complete()-1341: RX Warning!
[68093.855682] usb_read_port_complete()-1341: RX Warning!
[68093.855804] usb_read_port_complete()-1341: RX Warning!
[68093.855834] usb_write_port_cancel
Retry
Power Management
lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 3.02
iSerial 1 musb-hdrc
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 3.02
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
Hub Port Status:
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x7392
idProduct 0x7811
bcdDevice 2.00
bLength 9
bDescriptorType 2
wTotalLength 46
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)
dmesg | grep -i usb
