Some Questions Needs To Be Answered :)
streak
Poland & UK // Currently: Ipswich
www.openpandora.pl
Hi again
Have few quick questions:
Do we have on pandora:
- IRC Client
- QT dev Libs [for development]
- Gambas2 [dont ask :) i need it for work (sometimes its betted to create GUI in gambas for many .sh scripts, than use it in terminal mode)]
- FreePascal / Lazarus [Would like to compile some of my older stuff onto Panda]
- Small PHP Server [cherokee lite / apache lite with php5 ext.]
- Some good programmer's editor
- python
cheers
StrK
StreaK said:
- IRC Client
Xchat is on nand
OP use 4.6.2, I'm also offering 4.7.1
Not yet, but the later should be easy to build
check the repo, you have some choice here. Would recommande gedit (but well I use vi).
StreaK said:
On nand as well as many python modules
