Problems Compiling Busybox
jose1711
Slovakia
hello, i used devkitGP2X for linux to build the latest busybox. after running i get this error though:
CODE
./busybox: /lib/libc.so.6: version `GLIBC_2.3' not found (required by ./busybox)
./busybox: /lib/libc.so.6: version `GLIBC_2.3.4' not found (required by ./busybox)
Indeed, libc on gp2x is of version 2.2.5 but I was not able to use older version for creating gp2x toolchain. Can you help please? Thanks. Jozef
Static linking will let you run it.
If you need dynamic linking, your toolkit needs to use the old libraries, or use the open2x firmware and toolkit to get compatible libraries.
Thank you!
