Pandora .pnd with installer, using gksudo, sometimes not working
Hi !
So i bundled a .pnd with those first lines :
if zenity --question --title="My installer" --text="Welcome.\n\nDo you want to install it ?" --ok-label="Yes, of course" --cancel-label="Cancel" ; then
	#installing some ipk
	/usr/bin/gksudo "/usr/bin/opkg --nodeps install /mnt/pnd/my_installer_data/ipk/*.ipk"
	#installing the root filesystem into /
	/usr/bin/gksudo "/bin/tar zxvf /mnt/pnd/my_installer_data/my_root_pack-1.0-armv7a-1.tgz -C /"
        touch /test
fi
My problem is that sometimes, gksudo doesn't ask the password, therefore commands are not executed.
And test is created...
I don't understand...
Oh, btw, i know gksudo, as sudo does, caches the password during a limited amount of time. I tested installs on fresh systems.
Don't know if this will help, but here is the script I've used in a couple of PNDs to load a module (with password prompt). Courtesy of sebt3.
if ! grep -q snd-seq /etc/modules;then
  # the module isn't loaded
  gksudo -D "TiMidity++ needs to load the MIDI module snd-seq blah blah blah." "modprobe -k snd-seq"
fi
Strange behaviour.
Maybe invoke gksudo with the "--debug"-option, and see if it prints some helpful messages?
Ok, thanks, i'll try it soon.
Saw other useful options, like force sudo :
gksudo [-u <user>] [options] <command>
--debug, -d
Print information on the screen that might be useful for diagnosing and/or solving problems.
--user <user>, -u <user>
    Call <command> as the specified user.
--disable-grab, -g
    Disable the "locking" of the keyboard, mouse, and focus done by the program when asking for password.
--prompt, -P
    Ask the user if they want to have their keyboard and mouse grabbed before doing so.
--preserve-env, -k
    Preserve the current environments, does not set $HOME nor $PATH, for example.
--login, -l
    Make this a login shell. Beware this may cause problems with the Xauthority magic. Run xhost to allow the target user to open windows on your display!
--description <description|file>, -D <description|file>
    Provide a descriptive name for the command to be used in the default message, making it nicer. You can also provide the absolute path for a .desktop file. The Name key for will be used in this case.
--message <message>, -m <message>
    Replace the standard message shown to ask for password for the argument passed to the option. Only use this if --description does not suffice.
--print-pass, -p
    Ask gksu to print the password to stdout, just like ssh-askpass. Useful to use in scripts with programs that accept receiving the password on stdin.
--su-mode, -w
    Force gksu to use su(1) as its backend for running the programs.
--sudo-mode, -S
    Force gksu to use sudo(1) as its backend for running the programs.
$ /usr/bin/gksudo -u root -D "Installing some ipk packages" --debug --sudo-mode "/usr/bin/opkg --nodeps install /mnt/pnd/my_installer_data/ipk/*.ipk"
No ask_pass set, using default!ll & )naoh:~$
xauth: /tmp/libgksu-aAv25N/.Xauthority
STARTUP_ID: gksudo/|usr|bin|opkg --nodeps install |mnt|pnd|my_installer_data|ipk|*.ipk/6511-0-naoh_TIME0
cmd[0]: /usr/bin/sudo
cmd[1]: -H
cmd[2]: -S
cmd[3]: -n
cmd[4]: -p
cmd[5]: GNOME_SUDO_PASS
cmd[6]: -u
cmd[7]: root
cmd[8]: --
cmd[9]: /usr/bin/opkg
cmd[10]: --nodeps
cmd[11]: install
cmd[12]: /mnt/pnd/my_installer_data/ipk/*.ipk
buffer: --
buffer: --
brute force GNOME_SUDO_PASS ended...
No password prompt found; we'll assume we don't need a password.
xauth_env: (null)
dir: /tmp/libgksu-aAv25N
Collected errors:
 * wfopen: /mnt/pnd/my_installer_data/ipk/*.ipk: No such file or directory.
 * pkg_init_from_file: Failed to extract control file from /mnt/pnd/my_installer_data/ipk/*.ipk.
What the heck !!! "No ask_pass set"
It used to work perfectly some weeks ago. Can it be the Hotfix 5 ?
---EDIT :
using --su-mode asked for password, but command failed anyway !
I did a "ls /mnt/pnd/my_installer_data/ipk/" , and it showed all my .ipk :/
I don't really understand the gksudo/X internals, but maybe that is a pointer to the problem:
http://linux.derkeiler.com/Mailing-Lists/Ubuntu/2007-01/msg01300.html
[snip]
russell@abraham:~ $ gksudo -d -u dashboard xterm No ask_pass set,
[snip]
If you are running X as "russell", the system will complain if you try to
run an X app as another user ( the other user does not "own" the X
session on display :0 , and is not authorised to connect to the X server
for that display)
Try to add a "xhost +" in front of the call, that should allow anyone to connect to the x (only as a test, I don't know how secure or insecure that is. As I said, I'm not exactly an x pro)
Ok, will try it next. I'm too tired for now :^) better go sleeping.
BTW gksudo is executed by the current user so this should not be a problem...
I wonder another thing. The current script is called by another script, the one in the root of my .pnd
Is this chaining bad with .pnd ?
That's how i proceeded...
Anyway, my icon doesn't works, and the gksudo stopped working some days ago TT.
