darklight1138
- Dec 27, 2010
- 269
Hey guys. Two quick questions.
1 - In MAME, when you rotate the screen and use the I and II buttons, on some games those buttons work fine but they will also function as the insert coin function and so you'll be pressing it to fire during the game and you;ll get the little credit jingle if you know what I'm saying. Any way to change that?
2 - Also it may be obvious but I have never found instructions for how to use the audio buffer on GPSP. It seems to me that the higher the buffer the better the sound quality, but I have seen some instances where the audio is out of sync or delayed with the video. What is the best setting?
Ok, thanks!
Ok, thanks!
