b_o_b
- Sep 7, 2010
- 1,498
I have a Linksys WUSB54GC works on my linux desktop and seems to be recognized by my Pandora ('s) but it doesn't automatically work after plugging it in. According to posts regarding USB WIFI dongles it should be working without setting it up. Hope someone can assist.
[SIZE=14.3999996185303px] [/SIZE]
sudo iwconfig
sudo lsusb -v
demsg (has some error messages)
sudo iwconfig
lo no wireless extensions.
usb0 no wireless extensions.
wlan0 IEEE 802.11bg ESSID
ff/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry long limit:7 RTS thr
ff Fragment thr
ff
Encryption key
ff
Power Management
n
Encryption key
Power Management
sudo lsusb -v
bus 002 Device 002: ID 13b1:0020 Linksys WUSB54GC 802.11g Adapter
[ralink rt73]
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x13b1 Linksys
idProduct 0x0020 WUSB54GC 802.11g Adapter [ralink rt73]
bcdDevice 0.01
iManufacturer 1 Cisco-Linksys
iProduct 2 Compact Wireless-G USB Adapter
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 300mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0011
Per-port power switching
No overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 5 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0100 power
Device Status: 0x0001
Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.02
iManufacturer 3 Linux 3.2.63 ehci_hcd
iProduct 2 OMAP-EHCI Host Controller
iSerial 1 ehci-omap.0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
wHubCharacteristic 0x0009
Per-port overcurrent protection
bPwrOn2PwrGood 10 * 2 milli seconds
DeviceRemovable 0x00
Hub Port Status:
Port 2: 0000.0503 highspeed power enable connect
Port 3: 0000.0100 power
Self Powered
[ralink rt73]
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
bcdDevice 0.01
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 300mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
(Bus Powered)
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Self Powered
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 3.02
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 3
Hub Port Status:
Self Powered
[ 41.935607] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 41.935607] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 41.935607] usb usb2: Product: OMAP-EHCI Host Controller
[ 41.935638] usb usb2: Manufacturer: Linux 3.2.63 ehci_hcd
[ 41.935638] usb usb2: SerialNumber: ehci-omap.0
[ 41.938171] hub 2-0:1.0: USB hub found
[ 41.938232] hub 2-0:1.0: 3 ports detected
[ 42.263366] usb 2-2: new high-speed USB device number 2 using
ehci-omap
[ 42.606079] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 42.606109] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 42.606140] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 42.606140] usb 2-2: Manufacturer: Cisco-Linksys
[ 43.195159] cfg80211: Calling CRDA to update world regulatory
domain
[ 43.443115] usb 2-2: reset high-speed USB device number 2 using
ehci-omap
[ 44.506744] ieee80211 phy0: Selected rate control algorithm 'pid'
[ 44.507720] Registered led device: rt73usb-phy0::radio
[ 44.507843] Registered led device: rt73usb-phy0::assoc
[ 44.507934] Registered led device: rt73usb-phy0::quality
[ 44.509582] usbcore: registered new interface driver rt73usb
[ 44.805877] rt73usb 2-2:1.0: firmware: requesting rt73.bin
[ 44.958465] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 48.024047] usb 2-2: USB disconnect, device number 2
[ 49.075805] usb 2-2: new high-speed USB device number 3 using
ehci-omap
[ 49.418090] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 49.418121] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 49.418151] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 49.418151] usb 2-2: Manufacturer: Cisco-Linksys
[ 49.552368] usb 2-2: reset high-speed USB device number 3 using
ehci-omap
[ 50.039367] ieee80211 phy1: Selected rate control algorithm 'pid'
[ 50.041412] Registered led device: rt73usb-phy1::radio
[ 50.041687] Registered led device: rt73usb-phy1::assoc
[ 50.041900] Registered led device: rt73usb-phy1::quality
[ 50.301513] rt73usb 2-2:1.0: firmware: requesting rt73.bin
[ 50.404296] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 50.758361] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 51.422668] usb 2-2: USB disconnect, device number 3
[ 51.422912] phy1 -> rt2x00usb_vendor_request: Error - Vendor
Request 0x06 failed for offset 0x308c with error -19.
[ 59.380493] usb 2-2: new high-speed USB device number 4 using
ehci-omap
[ 59.722808] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 59.722839] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 59.722839] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 59.722839] usb 2-2: Manufacturer: Cisco-Linksys
[ 59.857055] usb 2-2: reset high-speed USB device number 4 using
ehci-omap
[ 60.344299] ieee80211 phy2: Selected rate control algorithm 'pid'
[ 60.346435] Registered led device: rt73usb-phy2::radio
[ 60.346679] Registered led device: rt73usb-phy2::assoc
[ 60.346923] Registered led device: rt73usb-phy2::quality
[ 60.607604] rt73usb 2-2:1.0: firmware: requesting rt73.bin
[ 60.708862] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 60.902160] wpa_supplicant: unhandled page fault (11) at
0x00000000, code 0x017 (read)
[ 60.902191] wpa_supplicant: pc=4029d084 (libc-2.9.so+6d084),
lr=401e8acc
[ 72.563629] uncorrectable error :
[ 72.563751] uncorrectable error :
[ 72.563964] UBI warning: ubi_io_read: error -74 (ECC error) while
reading 1319 bytes from PEB 2697:69016, read only 1319 bytes, retry
[ 255.236511] usb 2-2: USB disconnect, device number 4
[ 255.966430] usb 2-2: new high-speed USB device number 5 using
ehci-omap
[ 256.308441] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 256.308471] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 256.308471] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 256.308502] usb 2-2: Manufacturer: Cisco-Linksys
[ 256.443023] usb 2-2: reset high-speed USB device number 5 using
ehci-omap
[ 256.929809] ieee80211 phy3: Selected rate control algorithm 'pid'
[ 256.930664] Registered led device: rt73usb-phy3::radio
[ 256.930755] Registered led device: rt73usb-phy3::assoc
[ 256.930877] Registered led device: rt73usb-phy3::quality
[ 262.869812] usb 2-2: USB disconnect, device number 5
[ 265.903900] usb 2-2: new high-speed USB device number 6 using
ehci-omap
[ 266.088043] usb 2-2: device descriptor read/all, error -71
[ 266.146087] hub 2-0:1.0: unable to enumerate USB device on port 2
[ 311.528961] usb 2-2: new high-speed USB device number 8 using
ehci-omap
[ 312.091369] usb 2-2: device not accepting address 8, error -71
[ 312.216369] usb 2-2: new high-speed USB device number 9 using
ehci-omap
[ 312.558410] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 312.558410] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 312.558441] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 312.558441] usb 2-2: Manufacturer: Cisco-Linksys
[ 312.692962] usb 2-2: reset high-speed USB device number 9 using
ehci-omap
[ 312.763336] phy4 -> rt2x00usb_vendor_request: Error - Vendor
Request 0x09 failed for offset 0x0000 with error -19.
[ 312.763580] phy4 -> rt73usb_init_eeprom: Error - Invalid RT
chipset detected.
[ 312.763763] phy4 -> rt2x00lib_probe_dev: Error - Failed to
allocate device.
[ 312.769165] usb 2-2: USB disconnect, device number 9
[ 313.240142] usb 2-2: new high-speed USB device number 10 using
ehci-omap
[ 313.310180] hub 2-0:1.0: unable to enumerate USB device on port 2
[ 313.708587] usb 2-2: new high-speed USB device number 11 using
ehci-omap
[ 314.050659] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 314.050689] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 314.050689] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 314.050720] usb 2-2: Manufacturer: Cisco-Linksys
[ 314.185150] usb 2-2: reset high-speed USB device number 11 using
ehci-omap
[ 314.672210] ieee80211 phy5: Selected rate control algorithm 'pid'
[ 314.673095] Registered led device: rt73usb-phy5::radio
[ 314.673187] Registered led device: rt73usb-phy5::assoc
[ 314.673278] Registered led device: rt73usb-phy5::quality
[ 322.580047] usb 2-2: USB disconnect, device number 11
[ 338.802337] usb 2-2: new high-speed USB device number 12 using
ehci-omap
[ 339.144531] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 339.144531] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 339.144561] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 339.144561] usb 2-2: Manufacturer: Cisco-Linksys
[ 339.278961] usb 2-2: reset high-speed USB device number 12 using
ehci-omap
[ 339.765869] ieee80211 phy6: Selected rate control algorithm 'pid'
[ 339.767364] Registered led device: rt73usb-phy6::radio
[ 339.767639] Registered led device: rt73usb-phy6::assoc
[ 339.767913] Registered led device: rt73usb-phy6::quality
[ 339.810974] usb 2-2: USB disconnect, device number 12
[ 340.396087] hub 2-0:1.0: unable to enumerate USB device on port 2
[ 372.376708] aufs test_add:261:mount[2253]: uid/gid/perm
/mnt/pnd/op_usbhost 1000/100/0755, 0/0/0777
[ 372.774353] ehci-omap ehci-omap.0: remove, state 4
[ 372.774383] usb usb2: USB disconnect, device number 1
[ 372.793701] ehci-omap ehci-omap.0: USB bus 2 deregistered
[ 378.847351] aufs test_add:261:mount[2474]: uid/gid/perm
[ 379.352233] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 380.356994] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 380.357025] sched: RT throttling activated
[ 380.357208] ehci-omap ehci-omap.0: new USB bus registered,
assigned bus number 2
[ 380.358276] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 380.372619] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 380.372741] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 380.372772] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 380.372772] usb usb2: Product: OMAP-EHCI Host Controller
[ 380.372772] usb usb2: Manufacturer: Linux 3.2.63 ehci_hcd
[ 380.372802] usb usb2: SerialNumber: ehci-omap.0
[ 380.375488] hub 2-0:1.0: USB hub found
[ 380.375549] hub 2-0:1.0: 3 ports detected
[ 380.700805] usb 2-2: new high-speed USB device number 2 using
ehci-omap
[ 381.043304] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 381.043334] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 381.043334] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 381.043334] usb 2-2: Manufacturer: Cisco-Linksys
[ 381.177429] usb 2-2: reset high-speed USB device number 2 using
ehci-omap
[ 381.664733] ieee80211 phy7: Selected rate control algorithm 'pid'
[ 381.665588] Registered led device: rt73usb-phy7::radio
[ 381.665710] Registered led device: rt73usb-phy7::assoc
[ 381.665802] Registered led device: rt73usb-phy7::quality
[ 445.899017] usb 2-2: USB disconnect, device number 2
[ 446.224212] usb 2-2: new high-speed USB device number 3 using
ehci-omap
[ 446.566314] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 446.566345] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 446.566345] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 446.566375] usb 2-2: Manufacturer: Cisco-Linksys
[ 446.700775] usb 2-2: reset high-speed USB device number 3 using
ehci-omap
[ 447.187683] ieee80211 phy8: Selected rate control algorithm 'pid'
[ 447.189208] Registered led device: rt73usb-phy8::radio
[ 447.189453] Registered led device: rt73usb-phy8::assoc
[ 447.189758] Registered led device: rt73usb-phy8::quality
[ 474.330474] usb 2-2: USB disconnect, device number 3
[ 474.653900] usb 2-2: new high-speed USB device number 4 using
ehci-omap
[ 474.996032] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 474.996063] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 474.996063] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 474.996063] usb 2-2: Manufacturer: Cisco-Linksys
[ 475.130523] usb 2-2: reset high-speed USB device number 4 using
ehci-omap
[ 475.617401] ieee80211 phy9: Selected rate control algorithm 'pid'
[ 475.618286] Registered led device: rt73usb-phy9::radio
[ 475.618377] Registered led device: rt73usb-phy9::assoc
[ 475.618469] Registered led device: rt73usb-phy9::quality
[ 550.543792] usb 2-2: USB disconnect, device number 4
[ 550.872650] usb 2-2: new high-speed USB device number 5 using
ehci-omap
[ 551.214721] usb 2-2: New USB device found, idVendor=13b1,
idProduct=0020
[ 551.214752] usb 2-2: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[ 551.214752] usb 2-2: Product: Compact Wireless-G USB Adapter
[ 551.214782] usb 2-2: Manufacturer: Cisco-Linksys
[ 551.349273] usb 2-2: reset high-speed USB device number 5 using
ehci-omap
[ 551.836212] ieee80211 phy10: Selected rate control algorithm 'pid'
[ 551.837066] Registered led device: rt73usb-phy10::radio
[ 551.837188] Registered led device: rt73usb-phy10::assoc
[ 551.837280] Registered led device: rt73usb-phy10::quality
idProduct=0002
SerialNumber=1
ehci-omap
idProduct=0020
SerialNumber=0
domain
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
lr=401e8acc
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
ehci-omap
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
chipset detected.
allocate device.
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
Driver
idProduct=0002
SerialNumber=1
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
ehci-omap
idProduct=0020
SerialNumber=0
ehci-omap
