Issue with right nub
Null
Snug
elderberry.sdf-eu.org
My right nub currently doesn't register any movement on the vertical axis, my Pandora is a 256MB model running SuperZaxxon Final, it has had both its nubs replaced by EvilDragon about a month ago with the improved ones.
Fixes i've tried:
Reflashing the firmware, no change
Flashing Zaxxon-HF6, neither nub registered movement on any axis
Resetting the nubs via the nub configurator, no change
Leaving the battery out for 40mins to reset the nubs, no change
Pressing on the casing surrounding the nub, no change
Ejecting the left SD Card, no change
Ejecting the right SD Card, no change
Nub dance, worked once but no luck since then
Can anyone suggest anything else that I could try?
Sounds like a hardware issue to me (one of the pins lost contact). Probably when ED was replacing nubs he didn't heat one of the pins enough (which is understandable as heating too much would burn the board).
