Sonict
- Oct 2, 2008
- 50
- Age
- 40
- Location
- Mississauga, Ontario: Canada
- Website
- sonict.sepwich.com
I don't understand how the current setup on the Pandora is any different from the how it works on the PSP other then notifying the user how to setup the SD card directories for the first time and where to place it. If anything, an alternate way could be you navigate to the PND and run it like how you would do it with an executable. I believe currently, you have to go through hoops to do this.
Right now, the system works well since I had to use a similar system on the PSP and it works fine.
