Genisis help
coolgpguy
cal
I am really having problems w/ the genisis emu. I did everything like putting the file in gpmm and making the folder. I have the bin-smd converter to but it still wouldnt work. So i went to the website that gives u the compatability list and it still wouldnt work :blink:
yea there was a black line and red stuff flashing inside of it and i did put it in gpmm/Genisis wat do u think is wrong w/ it? :blink:
The flashing line is normal. This is the rom selection menu.
You should see all your roms here.
Be sure that the directory is gpmm/genesis, as you misspelled the genesis a few times in your post (it's NOT genisis, but genesis!)
