Flash Sound
zanven
I loaded a few flash videos (.swf) that have music to them but when played through the WIZ they are silent. Yes the volume is all the way up :P
Anyone experience this and any solution? It is not why I have the WIZ so I won't be too annoyed if I don't solve it but would like to try.
from what i remember, the sounds inside the swfs need to have the correct format to get them working.
i dont think the player eats all swfs with all embedded music, you need to be lucky - i guess it was .ogg that is supported.
That makes sense. Thanks.
Is there a way to detect what format the sound that is embedded is?
Also, is there a non-native flash player that has more compatibility?
