Compiling Sdl_Sound
Madrid
Has anyone tried to compile SDL_sound for the Wiz? (specifically, with OGG support via Tremor). Since I couldn't get the official "configure" script to work, I tried using code::blocks and the latest official libraries (the ones that come with the recently released 10.02 SDK). After a few tries it compiled and linked fine (my first attempts didn't link correctly and returned "symbol lookup errors"). I could see my example program starting on Qtopia's terminal and output some preliminary debug messages, but then it'd exit on this error:
*** glibc detected *** malloc(): memory corruption: 0x000bd840 ***
The same program runs fine on the PC.
I had to change a couple of lines in the source code so it'd use libivorbis (fixed point Vorbis implementation, it comes preinstalled in the Wiz) instead of the standard libvorbis which SDL_sound uses on the PC. Maybe those changes broke something, I don't know. Would this be worth debugging? I mean, I come from a Java background and I'm still catching up, so maybe the problem is a bit advanced for me yet.
If anyone has tried compiling SDL_sound with OGG support and is willing to share their findings (and, why not, binaries and sources :P ), I'd be grateful. I know this same library was ported to the GP2X but I only found the binaries (I'd have to ask the authors for the code) and they don't seem to come with OGG support (or at least I didn't see anything relevant with readelf).
Be aware there may be alignment issues with SDL_sound. Try running with
echo 2 > /proc/cpu/alignment
You can also use gdb from the gp2x (if you see pthread errors just hit 'c'
Thanks, that seems to have worked :) I'm now getting another error though:
./2DTutorial.gpe: /lib/libvorbisidec.so.1: no version information available (required by ./libSDL_sound.so)
Aborted
I didn't find anything relevant related to versions and such in the source code. How could I fix it?
 Aborted
is libvorbisidec.so.1 in the same folder as your binary 2DTutorial.gpe?
The abort may not be related to the library message, ive seen that message and had ill effects. I would use gdb and set a breakpoint at main and see if you get there and if so how far can you run until the abort occurs
 Aborted
It wasn't, I moved it there and it now works great, thank you :) My SDL_sound port crackles and segfaults but that's another story :P The program starts and runs fine, which was the point, so I'll now try debugging SDL_sound, although it doesn't seem like an easy task. Thanks again.
(If anyone is working on an SDL_sound port with OGG support I'll be glad to hear about it).
  Aborted
you could always use vorbis directly
