Change nub behaviour with pyrainput to control mouse cursor with right nub
jedi23
Very Active Member
I want to swap the mouse control behaviour of the left and right nub, so that i can move the curser with the right nub.
I looked into the funkeymonkey-pyrainput package. There is a /etc/pyrainput.cfg file and the readme provides possible configurations for it.
So I inserted this into the pyrainput.cfg
nubs.right.x            = [*mouse_x*|mouse_y|mouse_btn|scroll_x|scroll_y]+
nubs.right.y            = [mouse_x|*mouse_y*|mouse_btn|scroll_x|scroll_y]+
nubs.left.x            = [mouse_x|mouse_y|*mouse_btn*|scroll_x|scroll_y]+
nubs.left.y            = [mouse_x|mouse_y|mouse_btn|scroll_x|*scroll_y*]+
and reloded the configuration with
$ systemctl reload pyrainput
but it doesn't work as expected.
Any ideas?
Inside a dbp package you should use pyrainputctl
Create a file pyrainput.cfg and next run pyrainputctl overload pyrainput.cfg
I have done like this on Halloween3D game:
nubs.left.x = mouse_btn
nubs.left.y = scroll_y
nubs.right.x = mouse_x
nubs.right.y = mouse_y
nubs.left.click = mouse_left
nubs.right.click = mouse_right
mouse.export = 1
and in the runscript i have done:
#!/bin/bash
pwd=`dirname $(readlink -f "$0")`
cd "$pwd"
echo "--------------------------------------------------------------"
echo "Setting PATH to $pwd:$PATH"
export PATH=$pwd:$PATH
echo "Setting HOME to $pwd"
export HOME=$pwd
export XDG_HOME_DIRS=$pwd
if [ ! -d "system" ];then
zenity --$zentype --title "Halloween 3D" --width 600 --text "<span color=\"blue\">Halloween 3D Drangonbox Pyra release</span>
<span color=\"red\"Now unpacking Game Datas to appdata....please Wait</span>
<span color=\"red\">This will happen only on the first run !!</span>"
tar xf distrib.tar.gz
fi
if [ ! -e "system/hconfig.cfg" ];then
cp hconfig.cfg.sav "system/hconfig.cfg"
fi
if [ ! -e "$pwd/pyrainput.cfg" ];then
cp "$pwd/pyrainput.sav" "$pwd/pyrainput.cfg"
fi
sudo pyrainputctl overload "$pwd/pyrainput.cfg"
export LIBGL_ES=1
gl4es ./Hallow999 $*
sudo pyrainputctl no-overload
All of this "knowledge" is from studing @ptitSeb scripts :cool:
That's just how I had in my mind. But now I don't have to invent the wheel for a second time.
Thank you very much :cool:
