VMUDingoo 0.1 - Sega Visual Memory Emulator for Dingux 0.1
  • Author Author xzakox(dingux).Coccijoe(OD)
Intro and credits
VMUDingoo is a Dreamcast Visual Memory emulator for the
Dingoo A-320 Handheld running Linux.
It's based on the softvms emulator by Marcus Comsted.
ROM selection routine by Ester (^Misato^) from Vieju.Net
CPU Speed code by A600.
All other code is under the GNU GPL License (see LICENSE).
Installing
Just drop the vmudingoo folder on your SD card under local/
and make a link to vmudingoo.dge in your favourite dingux menu.
Then drop some VMS roms (only VMS are supported at the moment)
inside the roms/ folder and enjoy.
Controls
Controls are straightforward:
DINGOO VMU
D-PADD-PAD
A A
B B
STARTSLEEP
SELECT MODE
And L button for exiting from the current game and from the
ROM selector.
Known bugs
Some games run VERY fast, I have to check the CPU Timer
implementation.
Sound is buggy.
Volume is fixed.
NEW
Added OpenDingux version in the folder with some homebrew comptatible games
