Sachunsung 2 alpha
  • Author Author PotA
- Corrections
Apply button to clear (X button)
Move the analog joystick acceleration effect (temporary)
- Game rules
Everywhere have been either blocked or choose two blocks must be cleared.
However, the directions are blocked and there is also right next to the same block can be cleared by selecting.
Beyond that, the connection of two blocks of two or more times a course is not possible to select break ground.
Yes, I understand complicated explanations, and if you just go wrong.
Just keep going and enjoy ~^^..
- Use the key
Joystick: Move cursor
B button: select
X Button: Cancel
Y button: Help (3 limit)
I Button: Restart
HOME button: exit (Not Insanity)
- Touch
Select/Cancel a block.
MENU icon on the left: Never does not work.
HHH icon on the right: Help (3 limit)
(by http://translate.google.com ^^)
PotA
