POV-Ray2x 3.6
  • Author Author POV-Team / Grz- (gp2x port)
POV-Ray2x is a port of POV-Ray (Persistence of Vision Raytracer, http://www.povray.org) for gp2x.
Features:
- All POV-Ray features except TIFF images support.
- Custom real-time rendering (by lines or mosaic) preview for GP2X, built with minimal library from rlyeh.
- Rendering stats.
Controls:
- 'Start' (home) to stop rendering and quit.
You need to do your own .gpe/.gpu script (look at READMEgp2x.txt) to render your own scene.
The 'scenes' folder have a load of samples with a .gpe script you can directly launch to render.
To install, copy PovRay folder to the root of your SD card.
You can use the GP2X-write editor to create/edit scripts under GP2X, or any others editors editors you like.
Official website: http://www.povray.org
Official documentation: http://www.povray.org/documentation/
