Lord of the Rings Engine for Dingux 0.1
  • Author Author Michal Beneš (Ported by Shin-NiL)
Lord of the Rings Engine for Dingux v0.1 (19/07/2011)
Based on Michal Beneš Lord of the Rings Game Engine v0.6.5 [http://www.wonderland.cz/lotr/]
Dingux port by Shin-NiL [http://www.shinnil.co.cc]
Prerequisites to run the game
- Dingux installed with the latest elta's rootfs .
- Data files from the full game Lord of the Rings Vol. I for DOS.
Installing
- Extract the contents of the file 'lotr_dingux_v0.1.bin.zip' to your miniSD card.
- Copy all data from the Lord of the Rings game for DOS to the directory 'DATA', which is included in 'lotr'.
- Create a link with your favorite application launcher to the file 'lotr.dge'.
Controls
Most of the time simply press the indicated key to perform the desired action. Note that in the main menu, the buttons L/R move the cursor left/right pressing the A button to perform the action. Using the the virtual keyboard, move the directional to select, A button inserts the character and START confirms the entry.
