GUI for DUALBOOT Installation
  • Author Author NeoTheFix
A helpful little GUI to make installing DINGUX even easier!
HOWTO:
1) Plug Dingoo in the USB port holding B button and make a hard reset, screen stay black, but your PC should find a new hardware
2) Install the driver from Driver directory
3) Open the installer
4) Select your LCD module
5) Press Step 1 (DINGUX logo will appear at the screen)
6) Press Step 2 and follow the instructions on the Dingoo screen
Tested on Win7, based on original installer
NeoTheFix
