gmenu2x without overclocking limit
  • Author Author santino
This is gmenu2x ported by joyrider and unlocked by
santino to clock your dingoo from 50 up to 500 mhz.
But remember the Ingenic JZ4732 was designed to run
at 400 mhz so its a matter of luck how high you can
clock your dingoo till it freezes or gets fried.
Also if it not gets fried its lifetime will shorten
if you overclock it high and often.
So no warranty at all and use it at your own risk!
To use it just replace your gmenu2x binary with the
one coming in this archive. It should be located in
/local/gmenu2x on your sdcard.
santino
need some help?
irc#dingoonity on freenode
dingoonity.org
santino
