gmenu2x for dingux adapted sSVN R157
  • Author Author Massimiliano 'Ryo' Torromeo (original author), Joyrider (for the port)
This is a port of gmenu2x it has all the features of the original menu working. I fixed 2 small bugs in the original code (dealing with new links that didn't show correctly). I also added battery reading and a LCD Backlight setting, made the volume changing work and a few other things.
the menu needs to be placed in /boot/local/gmenu2x (and no other place, the zip already contains the gmenu2x folder so just extract to /boot/local).
You'll also have to edit the /boot/local/sbin/main script if you want this to be your default menu !
