Example of MLib
  • Author Author Mr. Spiv
A simple beta of mlib.. Controls: L+R to reboot, START and SELECT to toggle between two mods, A to play a 'NI', LEFT + RIGHT to adjust the master volume, UP + DOWN to toggle mod enable/disable. The 'red bar' going aroud the screen is the used 'raster time' per frame refresh. 12kHz output, 67.8MHz CPU speed... lame but.. time for the next project.
Mr. Spiv
