Drill2x Xtreme 1.0.3
  • Author Author JyCet
Enhanced version from Drill2x Final
1.0.3
-fix F200 compatibility by adding samplerate option in drill.ini
SAMPLERATE F100 F200
11025 YES YES
22100 YES NO
44100 (default) YES YES
-chg cpu speed from 60MHz to 66MHz by default du to samplerate increasing
but F100 owners can reduce samplerate to 22100 and cpu to 60MHz by drill.ini editing .)
v1.0.2
-fix infinite loop in title screen fade-out by pressing volup&B (thanks edd)
-compiled with new OPEN2X libpack (sdl 1.2.11) (speed up ~+10% minimum)
-cpu clock reduce from 66MHz to 60MHz (thank to OPEN2X lib team .))
(dont hesitate to visite www.open2x.org site and encourage the OPEN2X team :))
v1.0.1:
-fix 'i' missing in highscore (thanks thunor)
-fix missing volume control in pause mode (thanks Yod4z)
-add volume osd (Yod4z request)
-chg mainback.bmp by better fusion power's version thank you .)
-fix missing 'm.' display in game
-chg B button to START button to quit 'GAMEOVER'
JyCet
