C-Dogs SDL for Dingux 120909
  • Author Author Shin-NiL
This is a port of C-Dogs SDL v0.04 (http://icculus.org/cdogs-sdl) for Dingoo A320.
Overview
C-Dogs is a game for DOS.
The player character(s) are elite soldiers, taking on mission after missionto defeat evil in any form. That is, you kill it or blow it up. Sounds violent? Yep, that's right. Still, the emphasis is on gameplay rather than gore. But the game will involve a lot of mowing down of enemies - and the occasional unlucky civilian - so now you have been warned.
Installation
- Copy the cdogs directory somewhere on your filesystem
- Set your menu launcher to execute ./cdogs.dge
Dingoo Controls
The default dingoo controls are:
Control: Player 1:
Left Left pad
Right Right pad
Up Up apd
Down Down pad
Button 1 A Button
Button 2 Start Button
Common controls:
Automap Select Button
Pause Select Button (Any OTHER key continues)
Abort game Select Button twice
Button 1 is used to select menu items and to fire weapons in the game.
Button 2 is sometimes used to cancel operations.
In the game button 2 can be used to change weapons or, with directional controls, to slide.
Known Issues / TODO List
- This version only can be played by 1 player.
- Need to translate PC keys names to Dingoo buttons names.
- Setting resolution greater than 320 X 240 will crash the system.
- Setting video scale factor greater than 1 will crash the system.
- Shutting down Dingux improperly (not using poweroff command) will corrupt the savedata and display segmentation fault when exit the game. Deleting directory /local/home/.cdogs will correct this.
- The game is not at fullspeed yet.
Shin-NiL
